Welding opf MP35N
Welding opf MP35N
Welding opf MP35N
Can MP35N be welded.?
Also known as: UNS R30035; AMS 5758; Carpenter/Timken Latrobe MP35N.
roozle
Highest Regards,
Roozle
RE: Welding opf MP35N
Yes, but....
If you are using product in the 'cold worked & aged' condition you will not reach the same mechaical proerties in the welds (or HAZ). Depedning on the service and such you need to be careful where in the process sequence you weld with respect to cold working and heat treatments.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
