prevention of liquid discharge at stack outlet
do anyone perhaps have tips on how to prevent "infected" liquid droplets been discharge into the atmosphere.
The application is a scrubber system discharging through a Stack
RE: prevention of liquid discharge at stack outlet
Provide a de-entrainment section at the top of your scrubber, by using mesh pads made for that purpose.
Milton Beychok
(Contact me at www.air-dispersion.com)
http://www.deltatsystems.com/eliminatorsgrills.htm
The only limitation is that the gas flow has to be roughly horizontal, so the water can drain off the fancy louvers.
I'd guess the mesh pads would need some sort of drainage system, too.
Mike Halloran
Pembroke Pines, FL, USA
