Solid works default assembly template...
I can´t open an assembly window. Everytime I try an error pops up saying "The default templates are not valid". But in my options I have only got one template to chose from. Where can I get a default template that works?
RE: Solid works default assembly template...
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
dpepke ... Have you made custom templates? If so make sure the Tools > Options > System Options > Default Templates is pointing to them.
If that doesn't work, do a search in the SW install directory for *.asmdot. You will probably find it in C:\Program Files\SolidWorks\lang\english\Tutorial.
Change the location of the default templates to match.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
