Trailing Cable
Trailing Cable
We use a trailing cable to feed mobile mine equipment at 4160 V. I am trying to find any direction from the IEEE, NEC, or NFPA about how to handle this energized cable. The cable is appropriately insulated to be laid on the ground to feed the equipment, however there are concerns about handling the cable energized. Other than using linesmen gloves, is there something else we could try?
Thanks.
Thanks.
RE: Trailing Cable
RE: Trailing Cable
MSHA has regulations for handling high voltage cables. Look in CFR75.818. Their website is www.msha.gov. They may not be the governing body at your site, but this section of their law may give you some ideas on how to put a plan together.
Raisinbran
