inconsistent authentication code when running IDEAS 10
I have a problem with running Ideas 10 on Windows XP. I have already red all the tips and articles on this forum but haven't found the solution for mine.
The problem is that the flexlm server starts but in the debug file I get something like that:
22:51:42 (lmgrd) Done rereading
22:51:42 (lmgrd) FLEXlm (v8.1a) started on sebastian (IBM PC) (11/15/2005)
22:51:42 (lmgrd) FLEXlm Copyright 1988-2002, Globetrotter Software, Inc.
22:51:42 (lmgrd) US Patents 5,390,297 and 5,671,412.
22:51:42 (lmgrd) World Wide Web: http://www.globetrotter.com
22:51:42 (lmgrd) License file(s): D:\zainstalowane\IDEAS-10\sec\eds_id10.lic
22:51:42 (lmgrd) lmgrd tcp-port 7610
22:51:42 (lmgrd) Starting vendor daemons ...
22:51:42 (lmgrd) License daemon startup failed:
22:51:42 (lmgrd) CreateProcess error code: 0x3 File= D:\zainstalowane\IDEAS-10\sec\
22:51:42 (lmgrd) Started eds_id10 (pid 2348)
22:51:42 (eds_id10) Using options file: "D:\zainstalowane\IDEAS-10\sec\eds_id10.opt"
22:51:42 (eds_id10) Invalid license key (inconsistent authentication code)
22:51:42 (eds_id10) ==>FEATURE CoreMasterModeler eds_id10 10 permanent 2147483647 \ [...]
22:51:42 (eds_id10) ==>FEATURE MasterDrafting eds_id10 10 permanent 2147483647 8437 [...]
22:51:42 (eds_id10) ==>FEATURE AssemblySet eds_id10 10 permanent 2147483647 FAFA1CB [...]
22:51:42 (eds_id10) ==>FEATURE ManufacturingSet eds_id10 10 permanent 2147483647 \
and like that to the bottom...
My licence file looks like that:
SERVER sebastian 000f201fdd9c 7610
DAEMON eds_id10 D:\zainstalowane\IDEAS-10\sec\ options=D:\zainstalowane\IDEAS-10\sec\eds_id10.opt
INCREMENT FLEXLM_RL eds_id10 10 permanent 2147483647 9B1D332E8DED \
ISSUER=ISO ck=56
PACKAGE CoreMasterModeler eds_id10 10 8F1A3ADD1A48 \
COMPONENTS="MasterModeler_C MaterialDataSystem_C \
3D_IGES_Translator_C RPT_Translator_C VDA_Translator_C \
SET_Translator_C IDEAS_Plotting_C"
FC229C6DA463 ISSUER=ISO ck=137
PACKAGE MasterDrafting eds_id10 10 1ED4903578F8 \
COMPONENTS="Drafting_D 2D_IGES_Translator_D DXF_Translator_D \
IDEAS_Plotting_D"
and the OPT file:
INCLUDE ArtisanApplications USER Roginski
INCLUDE IDEASArtisanDrafting USER Roginski
hostname: sebastian
user name: Roginski
MAC adress: 000f201fdd9c
I have checked everything, is the licence file out of date?? Or there is something wrong with the OPT file??
Does anyone have an idea how to solve it??
Thank you very much
ISSUER=ISO ck=56
IDEAS_Plotting_D"
and the OPT file:
hostname: sebastian
user name: Roginski
Thank you very much
RE: inconsistent authentication code when running IDEAS 10
It doesn't look like the license is out of date as it appears to be a permanent license.
In the UK, licenses for I-DEAS provided by UGS have to be entered within 5 days of the date they are "cut". Was this entered straight away? and did you receive any direction to enter it within a certain timeframe.
Also suggest modifying the second line of the license file to explicitly select the license (although it should work as you have it) ie.
DAEMON eds_id10 D:\zainstalowane\IDEAS-10\sec\eds_id10.lic options=D:\zainstalowane\IDEAS-10\sec\eds_id10.opt
Have you set an environment variable for LM_LICENSE_FILE? Although if this was the problem the error would normally have be "License not found".
If none of this works then I'd suggest a reinstall.
Although in my flexlm manager I have paths to licence file and to lmgrd file specified when I am in Diagnostics and checking environment, all the fields are blank and "Effective LM_LICENCE_FILE=<not specified>".
It looks like the file manager see the file (use it, what can be seen in debug) but there is something wrong.
I entered the licence before 5 days time and I did't have any direction to enter it within a certain timeframe.
I have no idea what is wrong
Can anyone help??
To do so:-
Start > Control Panel > System > Advanced Tab > Environment Variable
Then under system variables select New
Within the Variable Name field type: LM_LICENSE_FILE
Within the Variable Value field type: D:\zainstalowane\IDEAS-10\sec\eds_id10.lic
Careful with the spelling of License.
If this does not work then mail me, I have another idea...
info at r-cad.com
So now it runs.
Thanks a lot
