undimensioned tolerance
I have a drawing that states the following :
Interpret drawing per ASMY14.100-200, dimensions and tolerances per ASME Y14.5M.
In the drawing all the dimensions in the drawing are untoleranced. Do I interpret these as basic dimensions?
RE: undimensioned tolerance
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
We do this if we buy a part as is and just want some dimensions for information purposes. It allows a receiving inspector to verify that we have a 1/4-20 x 1 inch long bolt, but he doesn't have to do a layout on the part.
It turns out I was not given all the information. I only recieved the drawing not the specification sheet with the tolerance block.
Maybe this is pulling hairs, but the drawing should simply say "INTERPRET DRAWING PER ASME Y14.100M." Since Y14.100M invokes Y14.5M, then it's redundant to invoke them both. Also I BELIEVE that Y14.100M says that the year of the standard should be left out of the callout (you might want to confirm this!).
Tunalover
