feed to jet pump
feed to jet pump
feed to jet pump
I HAVE 'INHERITED' A JET PUMP WHICH I WANT TO TRY OUT FOR SOLIDS UPLIFT OF MAX. 100 MM WITH A WATER PRESSURE NOZZLE DIA. OF 70 MM AND THE JET PUMP OUTLET DIA. OF 300 MM. CAN ANYONE RECOMMEND A SUITABLE FEED CENTRIFUGAL PUMP IN TERMS OF VELOCITY/PRESSURE RATING?
RE: feed to jet pump
balmey,
Generally ALL CAPS is taken as yelling and no one likes to be yelled at.
"Jet pump" is a pretty wide category of thermo-compressors that includes both ejectors (compressible power fluid) and eductors (incompressible power fluid).  To answer your question we would need to know what your power fluid is and if the "jet pump" is an eductor or ejector.
David
