Subways - Type LSZH Cable/Raceway
I am being told that type LSZH (low smoke, zero halogen) cable is required within subways? Can anyone provide a code reference to back this up?
My current design calls for THHN/THWN, in RMC. Do I need to specify LSZH cable/raceway instead?
Any insight would be appreciated.
RE: Subways - Type LSZH Cable/Raceway
I suspect this is a local building or fire code, probably not NEC.  You might try the NFPA forum if you don't get an actual answer here.
dpc
