Shrink Wrap for Grounding Cable
I am looking for a heat shrink wrap for a grounding cable to protect from synthetic hydraulic fluid, sky drol, fuel, UV, grease and any other wear and tear on a bonding strap MS25083. Any input ya'll have would be helpful.
RE: Shrink Wrap for Grounding Cable
As I suspect you have discovered, skydrol is bad news for many insulation materials but if you do a google search on "skydrol heat shrink" you'll get plenty of hits.
