SW2006 sp1 slow drawing opening.
Is anyone having problems opening simple drawings? We are seeing open times around two minutes for even the simplest parts after they were converted. Save, rebuild close and reopen does not change the times. The task manager is not seeing a hit on memory or cpu times. Dual xeon 3.2 2mb cache, 2 gig memory, nvidia 3400 pci express cards. Problems started when we moved from sw2005.
TAP
TAP
RE: SW2006 sp1 slow drawing opening.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
TAP
There are some process monitors which may help pinpoint where/what the problem is.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Cliff
My spaceball movements are very choppy as well, spinning a model with a mouse is fine.
TAP
