Ball valve standards
What US standards cover specification of ball valves?  Are there international (ISO etc) equivalents?
RE: Ball valve standards
Check out ASME B16.34 or ISA S75.04
Thanks gsxra.  I knew of B16.34, but not ISA S75.04: I'll check it out.
API 6D is common in the oil & gas industury.
Andy
Another USA ball valve spec. is MSS SP-110.  No ISO equivalent yet.
bcd
ANSI ('scuse me: ASME) B16.10 seems to be used frequently for face-to-face.
MSS-SP72
NACE MR01-75
API 6D
ASME ( I almost did it again)  B16.5/B16.34
ISO 6002
ISO 10434
ISO 15761
ISO 17292
ISO 14723 (if you are going subsea).
Some of these standards will have some equivalency as per API 6D/ISO 14313 for example.  Look them up.
Steve Jones
http://www.pdo.co.om/pdo/
API 608 & ASME B16.34 for design - press. temp ratings
ASME B16.10 for Dimensional standard
API 598 & 607 for Inspection & testing inc. Fire safe
When you get to larger sizes / higher press. then there are no Dimensional std. in B16.34.
