Cross referencing international standards
Problem: Trying to find equivalents between US (eg API/ASME/ANSI/ISA etc) and European/International (eg ISO/IEC/EN etc) standards in the areas of pressure piping, material selection, valves, rotating machinery (compressors etc), hazardous areas, electrical wiring etc etc.
Reason: Specifying small scale hydrogen generation plant for use in US, Canada and Europe.
Specifically: Does such a thing as an equivalent standards cross-reference database exist? For example, ISO nnnnn in Europe is equivalent to ANSI nnnnn in US. I know that generally US stds apply in US and ISO in Europe, but, for instance, if I specify ASTM A351 CF8M material for valve bodies in the US, is there a European equivalent to use when requesting valves from a European supplier?
RE: Cross referencing international standards
Look for the US standard by the writing orgainzation instead of ANSI. At the same time that we are moving toward international coordination I see few ASME, etc. specifications with ANSI on the cover.
John
Steve Jones
http://www.pdo.co.om/pdo/
