Dialog box display (2002)
I installed a free app dwggateway from the autodesk website. Since then I seem to have lost my dialogbox displays.
Simple commands like opening a file, saving etc goes through the command line. Now as much as I love the command line, it gets annoying to type in/copy the path to the file you require to open.
How can I get it back to display dialog boxes?
thanks
RE: Dialog box display (2002)
FILEDIA
ADT 2004
ACAD 2002
Thanks a bunch Exxit.
Are you sure you got that from the Autodesk website? That's an add-on tool created by an Autodesk competitor, Solidworks. I installed it a while back and it caused issues with AutoCAD so I had to uninstall it, not to mention I had to completely clean out the registry and reinstall AutoCAD from scratch to get it to work again.
ooops !. My mistake.
