Design table in assembly?
I have a pump assembly which comes in varing sizes and want to know if I can use a design table to alter the configs of each part within the assembly so I can select each size of pump and the assembly will change to suit.
RE: Design table in assembly?
I assume you are familiar with creating configs of parts ... creating configs of assemblies is similar. Instead of changing dimensions, the DT changes part configs.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
