ISA/IEC sizing question
I am looking for the equation for delta P across a control valve. I am looking for non-choked, compressible, turbulent flow with or without fittings attached. I have the equation to solve for C, but I was hoping someone has this equation re-worked for DP.
Josh
Josh
RE: ISA/IEC sizing question
For compressible flow you first have to determine the delta P to P1 ratio. Then Weight, Mass or Vapor basis and what kind of valve globe, ball or butterfly.
Y=1/(3FkxT), x=DP/P1
If
Cv= _Q_________
1360*P1*Y*Sqrt(X/GTZ)
And X=DP/P1
Substitute for X
Cv= _Q_________
1360*P1*Y*Sqrt(DP/P1GTZ)
Sqrt(DP/P1GTZ)=Q/CV*1360*P1*Y
(DP/P1GTZ)= (Q/CV*1360*P1*Y)^2
DP=Q^2*GTZ/P1^3*Cv^2*1360^2*Y^2
Q is in SCFH
P1 is inlet pressure in PSIA
Y is the expansion factor,(1-(X/3FkXt))
X Pressure drop ratio defined above
G specifig gravity (MW/29)
T=Temp in degrees R
Fk is specific heat ratio (ideal gas: 1.4)
Xt is terminal pressure drop ratio-from Mfr's tables)
Z is compressibility (ideal gas=1)
But you still need to break Y out (because Y=1-X/(3FkxT)).
When I do that I get a cubic equation for DP.
If you use your equation or the ISA one I listed same result.
I was hoping someone had the equation solved for me.
If you assume the valve to be choked, start by using a Y of 0.667 and see where that gets you.
If the valve is not choked, use a Y value between 0.667 and 0.93.
If you want Y broken out, assume Fk=1 for air, Xt~0.5 to 0.75 for a globe valve, and the x/Xt factor to be the Xt value or some pressure drop ratio lower than the Xt.
What type of control valve are you using?
Fred
As for the type of control valves: I have used Fisher, Masoneilan, Samson, CCI, ValvTechnologies Xactrols, etc.
I know what Fk and xT values I will be using. I was just hoping some would have the equation written to solve for DP.
If you have an inlet pressure and the xT value, you can calculate your downstream pressure and then the pressure drop.
Help me out. Knowing the formula is C=W/(N6*Y*[x*p1*rho1]^.5)
Y=1-(x/(3FkxT)), x=DP/P1, N6=63.3
Known:
W, N6, Fk, xT, P1. rho1, C
This leaves DP the only variable I don't have. But I don't remember my algebra that well to solve for DP.
When I solve for DP I get:
DP^3/(3*Fk*xT*P1)^2 - 2DP^2/(3*Fk*xT*P1) + DP = (W/C*N6)^2/rho1
As far as the equation goes, I wouldn't break up Y at first, use Y as 0.667 to begin with, or leave it as Y. When I went through the equation, I ended up with pressure drop on one side and W^2/(rho*C^2*N6^2*Y^2) on the other side, with the P1 term dropping off because it appears in the numerator and the denominator.
