Computing Impulse Response Function from FRF
I am trying to compute an impulse response function from a one-sided Frequency Response Function. How do I do that in Matlab?
RE: Computing Impulse Response Function from FRF
Cheers
Greg Locock
Ah OK, I've got it. If you zero the phase and IFFT the magnitude of the spectrum, then by definition when you re-FFT the resulting impulse there will be no phase information.
What's the 'correct' version, in signal processing terms?
Cheers
Greg Locock
In Matlab the steps to compute the IRF are as follows
1) Express the FRF in complex form: A*cos(theta) + i*A*sin(theta), where A is the magnitude and theta is the phase at each individual spectral line.
2) Convert the complex spectrum to the two-sided form required by Matlab. i.e. arrange the spectral lines in the frequency order:
[0 df 2df ... (fn-2df) (fn-df) fn -(fn-df) -(fn-2df) ... -2df -df]
Where df is the frequency spacing and fn is the Nyquist frequency. The complex values at the negative frequencies are the conjugate of the complex values at the associated positive frequencies.
3) Perform the inverse Fourier transform.
4) Check that you have done it correctly, by making sure that the IRF is purely real (there may be some VERY small - 15 orders of magniude smaller - imaginary part which is due to numerical errors and can safely be removed by taking the real part)
5) You may need to apply a scaling factor based on the length of the IRF divided by 2 and possibly a further factor of 2 depending on exactly what you mean by a "one-sided" spectrum.
M
Dr Michael F Platten
M
the array specified by Dr.Platten would have 8192 (including positive and 0 Hz) plus 8191 (negative spectral lines )? Is this correct?
A hint on step three is to check the enegy in the time domain and in the freq domain and find the scale factor to make them match. x * x' should do it for a column vector.
1) Scale your spectrum properly. The absolute value in each bin should be proportional to the number of points in the spectrum.
2) Matlab stores its spectrum starting from DC, going up to nyquist and then the negative frequencies back up to DC. So to reconstruct the spectrum you need to add the flipped conjugate to the end.
Having got the properly scaled double-sided spectrum, take the real part of the ifft().
M
frf is my frf row vector with 8192 points.
FRF=[frf,fliplr(conj(frf))];
irf=ifft(FRF);
irf=irf+conj(irf);
plot(irf)
But there is a problem with the plot, because it shows a exponentially decayed time signal at the beginning of x-axis and also a reversed exponentially decayed time signal at the end of x-axis. Am I doing something wrong?
FRF=[ frf 0 fliplr( conj( frf( 2 : end ) ) ];
then replace
irf=irf+conj(irf);
with
irf = real( irf );
Could you give us the first 4 complex numbers in the frf?
They might give us some insight.
-8.32218E-3+1.33314E-3i
-3.37827E-2+2.03763E-2i
-4.38152E-2+7.85120E-2i
It looks like a phase roll of about 10 degrees per picket so I would guess that you should have your impulse spike (assuming you have a basically flat freq response over most of the band) at about the 5th or 6th time data point.
Is the freq response flat to within a couple dB over 80% of the band?
Or is this some sort of high Q resonant problem? in which case my back of the envelope analysis is inadequate.
So, can you give us the first 14 time data values?
Can you give a snippet of a few points around where the HP edge has ended?
-0.00000000000000 + 0.00000000000000i
-0.00832218000000 + 0.00133314000000i
-0.03378270000000 + 0.02037630000000i
-0.04381520000000 + 0.07851200000000i
0.00500428000000 + 0.13423600000000i
0.06934280000000 + 0.12662800000000i
0.08197070000000 + 0.09926960000000i
0.09618740000000 + 0.11477100000000i
0.16896000000000 + 0.09298500000000i
0.17899000000000 - 0.02864460000000i
0.04210450000000 - 0.08325290000000i
-0.03197860000000 + 0.04724550000000i
0.11644800000000 + 0.11310100000000i
0.19826300000000 - 0.09455950000000i
If you plot the magnitude of that lot you'll see that there is probably far more information to come in that spectrum.
Cheers
Greg Locock
FRF_2side = [0 frf(2:end) 0 conj(frf(end:-1:2))];
irf = ifft(FRF_2side);
plot(real(irf));
Does the plot look OK (an oscillating decaying signal)?
Is max(abs(imag(irf))) very small (<1e-10)?
If the answer to both questions is "yes" then all you need to do is apply a scale factor to the irf (either multiply or divide by 8192 - I never can remember which).
If the answer to either of them is "no" then please tell me the sampling frequency in Hz of the original measurement and the frequency in Hz of the 1st, 2nd and last spectral lines in the FRF.
M
This IRF business is more complicated that I thought..
Does the IRF decay initially and then grow towards the end or does it start from zero and grow continuously?
I would expect some non-causal response at the far end of the IRF. This is normal, but I would expect the signal to decay for at least the first half of the IRF before it started to grow again.
How was the FRF measured? Random excitation? Hanning window? Number of averages? Averaging Overlap?
Is the structure very lightly damped? What is the typical critical damping ratio for the modes?
M
The image of IRF I got from using Dr. Platten's code can be found at http://www.cnuga.com/irf.html
The FRF was measured using impact hammer - rectangular window was applied on impact, no window on time response. Number of averages is 4. The data was zero-padded before evaluating the FRF.
If you have strange resonant system you are looking at, then you would want to carefully excite it with a stepped sine system, changing the input drive as a funcion of the resonant gain, so as to stay away from non-linear problems.
Now, if your first column was dB and your second degrees, then you might have something.
The data looks fine to me. The columns are the real and imaginary parts of the FRF as the original poster stated.
SrinivasAluri,
I think you must still have a mistake in your code somewhere. The results I got look OK. There is a very small non-causal response at the end of the IRF, but I have seen much worse on my own data.
Here is the code that I used
CODE
frf = frf_et(:,1)+i*frf_et(:,2); % form the complex FRF
fn = 640; % Nyquist frequency
df = fn/8192; % frequency spacing
freq = [0:df:fn-df]; % frequency vector
frf2 = [0 frf(2:end).' 0 frf(end:-1:2)']; % form 2-sided FRF
irf = ifft(frf2); % calculate IRF
dt = 1./2./fn; % sampling interval
time = 0:dt:16383*dt; % vector of sampling times
% plot the results
figure;
subplot(3,1,1);
plot(freq,abs(frf));
xlabel('Frequency (Hz)');
ylabel('FRF Magnitude');
subplot(3,1,2);
plot(freq,angle(frf));
ylabel('FRF Phase (rad)');
subplot(3,1,3);
plot(time,real(irf));
xlabel('Time (s)');
ylabel('IRF');
M
M
Also, if you are just using LSCE to get frequency and damping values, I wouldn't worry about the scaling factors discussed in earlier posts. The scaling will make no difference to the estimated frequency and damping values.
Finally, I would add that the FRF data you posted had rather a lot of modes in your frequency range. This means you will probably have to do the LSCE fit in smaller frequency ranges. In that case, you should simply band-pass filter the FRF prior to performing the IFFT. Simply set the unwanted spectral lines to zero.
Good luck
M
