OHSA 1000 lbs. Load Requirement
When designing for the 1000 lbs. concentrated load required in OHSA (29CFR1910)does the allowable stress of the steel need to be used or can the ultimate stress be used?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: OHSA 1000 lbs. Load Requirement
I know some of the requirements, as on scaffolding, call for the item to support "4 times the intended load without failure" or something of that sort. Which to me implies something like LRFD using a load factor of 4.
