Problems creating a new Standards Set
I am creating "company approved" standards for the toolbox, based on the Ansi Imperial and Metric standards. I created the Imperial set first, with a name "xyz - Imperial" and disabled all the stuff I don't need.
My issue is when I create a standard based on the Ansi Metric. I am not getting any of the 'nested folders', I see the "bolts and screws" heading, but there are no folders below this, so I can't specify any of the actually sizes within the standard. I tried from several different machines, and I am still getting the same issue.
Any thoughts?
phreaq
Has anyone seen my brain today? (^_^)
www.phreaq.net
RE: Problems creating a new Standards Set
It sounds like you need to do a repair on your install.
Another thought... are you working from a central toolbox on the network, or does each machine have its own toolbox installation?
The toolbox resides on the server, and we all access it.
Strange how I could do Imperial....
phreaq
www.phreaq.net
It sounds like it might be an issue with the toolbox files on the server, in that case.
