Hidden lines in a drawing
Hi everyone,
I have an assembly that I have done a isometrical view from. I would like to know if I can choose some of the hidden parts to be visible? I want them to be shown with hidden lines. If I go to properties for that view and turn on hidden lines then everything that was not visible before will be shown with hidden lines. I just want some parts to be shown. Is that possible?
/Magnus
/Magnus
RE: Hidden lines in a drawing
Also be careful when the view is updated following a geometry change!
/Magnus
You can find Overload Properties if you Rigth-click on the view and select "View Namne" object/Overlad Properties.
/Akesson
You can not only hide/show parts, but also change to different color/linetype. You can also select your parts from within drafting mode or from the assembly model. This is esspecially usefull when you have assemblies within assemblies, usually if you select from drafting it only selects one part model at a time, not the assembly.
