Changing colors of part surfaces
I am trying to change the color of certain faces of a part which is in an assembly. The problem is - the color does get changed in the part file, but once I go back to the assembly, the whole part shows up as monochrome. How can I avoid this?
RE: Changing colors of part surfaces
Keep it simple! Only change the face colour in the part file.
You may find the ModelColors and ModelProperties macros at http://webpages.charter.net/mkikstra/SolidWorks.html useful.
Also, the Face Color and Feature Color macros at http://mysite.verizon.net/mjlombard/
SW06 has simplified colour management with its Appearance Callouts
[img=http://img434.imageshack.us/img434/6318/appearancecallouts2gg.gif]
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
First, follow CorBlimeyLimey's advice, or you'll easily lose control of your face colors (by mixing face color changes within the context of an assembly, for example--don't do this).
The simple way to change a face is to select it, right click, and choose face properties.  You can change colors there.  (You can also CTRL-select multiple faces and do the same thing.)
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
