Burst pressure of MPVC
Hi there,
I wish to use 40mm MPVC pipe in the engine bay of my car to channel boost from turbo.
The pressure will be 15PSI + Engine heat.
Anyone know if the PVC will handle these factors?
Cheers
Martin
Cheers
Martin
RE: Burst pressure of MPVC
You need to go to the manufacturer of the mpvc to get the properites they will stand behind. Most manufactures have a web site you can go to if you want to find out the recommended working pressure, and how much to derate the pipe for a given temperature.
40mm ID and 43 OD
