Relay Driver/buffer 12V
Just need some help in identifying a popular semiconductor package(preferably NTE) to drive a 12V relay (approx 200mA) from a very low current +12V input
Relay Driver/buffer 12VRelay Driver/buffer 12V(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Relay Driver/buffer 12V
http
h
http
http://www.cel.com/pdf/datasheets/ps7113.pdf
http
http://www.cel.com/pdf/datasheets/ps71221.pdf
etc,etc.
A generic answer would be something like the venerable 2N2222. Since you want to buy from NTE, that would be a good place to start. If you are just building one, a catalouge shop cross reference should be OK. The IRF type FET's with logic drive might be easier for you and not cost much more, it depends on your sensitivity of NRE to production part costs.
Thnaks
http://www.onsemi.com/pub/Collateral/AND8116-D.PDF
This if for an ON semi automotive version NUD3124.
If the 12 V is realy a ra 12 V with glitches and noise and large swings in voltage from charging and EMF during operation, you might have to take some other precautions.
Drive it directly. If you must use your existing relay just use the smallest one to switch It. This gets you robust screw terminals and mounting holes that are fit for mounting on or around engines using ring connectors.
Something like:
http://dkc3.digikey.com/PDF/T053/1401.pdf
reasonable beta. Suggested:
NTE196/331 = TIP41
NTE181 = 2N3055
NTE261 = TIP125
Any of the above (and scads more) should be suitable.
If the base current becomes a problem, use a 2N3053 or
3054 (progressively larger), or in extreme cases, use
a 2N2222 (as suggested) or 2N4401.
You can look up the NTE equivalents yourself; they have
a cross-reference page.
<als>
