Is Radeon 7500c compatible with Catia V5?
Hi, I've installed Catia V5R15 on my labtop (Dell Inspiron 5100), the installation seems to be fine, but unfortunaterly I can't make it to run. I got this error: "No certified OpenGL library has been found" Can anyone tell me how to fix this?
RE: Is Radeon 7500c compatible with Catia V5?
h
Fernando
I'm considering buying a new PC just to make Catia work, because I really need this program for my project, but definitively not a Dell. Do they have a list of graphic card that is certified? Or do they have a way to go around that certified check?
http://www.opengl.org/applications/installing.html
First try to update the drivers. For a new PC I'm sure that you can find the answer using Google (its only an example, of course).
Fernando
That being said, if you run into a Bug, DS may not be able to fix it for unsupported hardware.
I'd also suggest trying to upgrade you directX (not sure if it will make a difference but it won't hurt to try). htt
I totally agree with you, there must be something wrong with my graphic driver. But to be honest, I can't seem to find the problem.
I did installed Directx 9.0c. It's still not working.
I didn't use the default drivers from Microsoft, I installed the original driver giving by Dell support, but I still have the feeling is not the right drivers. I went around the web to find a better driver, but it seems to be almost impossible to find one for 7500c. Anyhow, I found one from driverguide.com and when I installed it, it said graphic card driver is not installed or something like that.
Now I'm kinda confused, I uninstall the driver, install a new one with Ati Control and yet I still can't installed the driver I downloaded from driverguide.
I don't play game that much, the only game I have on my laptop is a Age Of Empire, and I do have a problem with it as well. As for 3d software, none... but I can't make X-Plane to work properly. Same problem with the OpenGL. I think the biggest problem is when I installed something about the OpenGL, but can't remember what I've installed...
I sound dump now, but I'm so desperately need to make Catia work.
I hate to say this, but, have you condsidered trying to re-install Windows? I had to re-install for a friends ACER Laptop but only to change to NTFS file system from FAT32.
Also if you look on your screen saver menu go to 3d maze(open gl) and see if that works.
So I'm still hesistating.
The drivers for your laptop you can download from their website so that should be no problem rather the opposite you get the newest drivers.
I have had no problem with Dell, HP workstations I think you can't blame the manufacturer for it but your self you might have some software installed antivirus, firewalls etc that might prevent it from work.
Are you actually running a licenced copy I mean isn't it a waist of money running an expensive license on a low end laptop especially since you're desperate to get it to work!
Thank you everyone for your replies.
Quick Question, do you guys know where is the best place to find some catia tutorial?
I'm in love with CATIA
Check FAQ
Fernando
First of all, you can use the User Companion for different workbenches.
Fernando
