Converting Wireframe to Solid in Catia V5
I've inherited a Product in which a Part is drawn as a wireframe helix (it's acutally a representation of a spring). I need to make it into a solid so that there is 3D geometry associated with it.
Can anyone give me a reliable solution, or tell me how to wrap a 3D surface around the 2D wire?
Interestingly, if I export it to a .model file, it seems to end up as a solid.
Thanks.
Thanks.
RE: Converting Wireframe to Solid in Catia V5
There is a helix command in v5 which will give you what you want or you can *close* the surface.
Take a look at wireframe and surfaces benchmark.
Fernando
