Need help with proper motor selection.
What is the best motor type to use for the following application?:
A portable tool (variable torque) operating at 24 VDC needing 1/2 hp full load at 10,000 rpm. Continuous operation, overall motor life at least 200 hours, speed control all required.
RE: Need help with proper motor selection.
Go to the motor manufacturers they will be able to steer you quickly.
AC/DC brushless motor from Baldor, Kollmorgen, etc.
fti, I have gone through my list of brushed dc motor suppliers but have drawn a blank - that combination of speed and power doesn't seem to be available, at least off the shelf.  Which is a pity as brushed dc would be the cheapest solution and sits quite happily with the relatively short lifetime requirement.
So I agree with blacksea, I think you are looking at a brushless dc motor - not so cheap.
- unless you consider brushed dc with a gearbox.
I would be considering using a tool driven by compressed air and using a fixed speed motor to drive a suitable compressor.
