NX2 discrepancy in face to face distance measurement
I have a parasolid created from a step, that was saved from Pro-e assembly file. My customer has rejected the model because they say the distance between two of the parts is incorrect. When I measure the distance between the two faces, one on each part, I get one measurement(132.38), and I measure the distance any other way(creating a perpendicular line between the two faces, dimensioning a view in drawing, placing two planes on each surface and measuring distance, etc.) I get 132.0(the correct number). These two faces are planer and parallel. Has anyone seen this problem? I need ammunition to go to my customer and explain what's going on. Thanks
RE: NX2 discrepancy in face to face distance measurement
Take care...
Take care....
