SW2006 Hole Wizard: decimals are gone!
I've been running SW2006 for a couple of days now and, for the most part, I really like it. I especially like the work done on the Hole Wizard, with one exception. The decimal equivalent of the inch size drill diameters used to be diplayed in the Hole Wizard dialog box, once a drill size was selected. This is not the case anymore. The Hole Wizard "Type" tab only shows the drill size in terms of it's nominal call-out (number, letter, or fraction). I wonder if there is a setting hidden away somewhere that controls this.
RE: SW2006 Hole Wizard: decimals are gone!
John
keep us posted on this one
You can select the drill size and down at the bottom of the wizard is a drop down for custom sizes. It shows the decimal equivalent there.
Dennis
SolidWorks 2006 SP1
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CADMAN
