EPS exporting - changes size of axes
I try to export a figure containing two axes into an eps file. The axes are covering each other, I use them because i need two y-xes.
The figure appearance is what I aime it to be until I use
print('-depsc2',nnam);
%nnam is a string with path/name of the file
using this command moves one of the axes lightly, so the axes cover no more both in the figure and in the exported file.
Befeore the export I set the 'Position' of the axes to be the same. I use latex/interpreted y-labels.
Thanks!
Thanks!
