"not less than" vs. "at least"
Which do you prefer?
I think "at least" is much better.
RE: "not less than" vs. "at least"
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
In a specification, if you ask for "at least", or "as a minimum", that is what you will get.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
NozzleTwister
Houston, Texas
However, I frequently encounter people who think that "at least" isn't proper legal or specification language.
Hg
Eng-Tips policies: FAQ731-376
Q: OK, how many independant testimonials are there to support this?
A pos: At least 3
A neg: Not more than 3
Subtle, to be sure.
A.
Your example is wrong if you intended the negative to mean the same as the positive. The neg should've been "No less than 3" to mean the same as your positive example.
NozzleTwister
Houston, Texas
