Current Limiting Reactor
3
I have two questions:
1. Where can I find the X/R ratio of a 3ph, 12.6 kV, 5%, 600A reactor?
2. I calculated the MVA rating of this reactor as follows:
1.73x12.6x600/1000=13.1 MVA. Is this correct?
kingi
RE: Current Limiting Reactor
1.  The manufacturer
2.  Yes
Mike
Thank you for your reply. I took the information from a drawing where the manufacturer was not mentioned. I wonder what would be the approximate X/R ratio for a similar series reactor?
kingi
Kingi-
It's impossible to accurately speculate. The Q-factor (X/R) varies substantially with design and even within designs of the same manufacturer.
Conrad St. Pierre's book, "A Practical Guide to Short-Circuit Calculations", has some curves in the Appendix for typical air core reactor X/R, depending on the conductor material.
For a 13.1 MVA reactor, the range for X/R is on the order of 40 to 70.
Thank you all. I didn't think the X/R ratio was that high.
kingi
If you know what the conductor material is, I can give you an equation for an approximate calculation of X/R.
It will still be quite a few watts of heat loss when you run the numbers out, since you're dealing with the square of the current.
DPC-
I seriously question that table you reference based on conductor material as being accurate (of course 40-70 is a huge range). There are many different types of winding and conductor profile configurations for air-core reactors...and i say that as someone who works for a reactor configuration.
Just my $0.02 worth.
scottf,
It's the same chart and equations that GE has referenced for years, I think.
