Bill of Materials - Add Block Sizes to Parts List
Does anyone know a way to have UG include overall X,Y,Z sizes of assembly components to the parts list? This would be especially helpfull in Mold Designs where the parts list have to include stock sizes for some of the assembly components. Running NX3 in Win XP.
Thank you.
Tim
Thank you.
Tim
RE: Bill of Materials - Add Block Sizes to Parts List
But be aware that Moldwizard is an infant. Every release gets better and/or changes...so don't get too used to anything...lol. It doesn't put that stock size in a slide body for example....you have to go into that file and create that attribute manually. Or...if you use the "Bill of Material" function in the MW toolbar you'll see a list of your components pop up. Then at the bottom you'll see an "Edit Stock Size" button. Select your component...hit "Edit Stock Size"...and then it will say something about a file not existing (it means the attribute)...hit continue and then it will change displayed part into that component and it will attempt to calculate the overalls of the solid you have in there. If you need to you can even select a different body for it to calculate. Once you hit "OK" it creates an attribute called "MW_STOCK_SIZE" and adds your stock size as the description. So...if you pulled that attribute you would get your stock size in your parts list. But that attribute doesn't exist in most of your mold parts so now you have an extra column in your BOM that is blank for 90% of the parts. Again...MW is yet to have one good way of doing it. Your best bet would be to go back into that file and change the attribute's name from "MW_STOCK_SIZE" to "CATALOG" so it shows up in the same column on your parts list as some of the other stuff will. But another frustrating note....that "Bill of Material" function often doesn't work. I often times can't get components to show up in the list for me to even do the "Edit Stock Size" command on. I haven't figured that one out yet. I can't seem to find what it's looking for at the assembly level in order to be recognized as a component and included in that list. But it will work sometimes....lol.
You have to create a lot of stuff manually in Moldwizard. Mold drawings are still a bit crude. And you end up having to do so much tweaking to the "canned" BOM functions that I just do my BOM's manually....it ends up being just as fast and at least that way I take a final in-depth look through my tool. If you get in the habit of setting a few attributes every time you add a chunk of steel you could use the "canned" parts list commands and have it turn out pretty nice....if you remember to set all those attributes...lol. Again..when all is said and done you have so much time into tweaking and creating stuff that you might as well have just typed it all in.
It just occured to me that you may need to know how to set attributes :) Right click on a file in your assembly navigator and then select "Properties". Then select the "Attributes" tab and you'll see them all. Another note...when creating attributes you should only do so with the part as your displayed part..that's the only way the attribute gets made properly. If you just make it your work part and set the attribute you'll notice that when you make the part your displayed part and check the attributes that one won't be there. It would only be "remembered" at the upper level you had displayed when you created it. That's fine if it's only going to be referenced in a drawing that is a part of that upper level, but if it's a library component for example...when that part is pulled into another assembly....that attribute wouldn't be there. So I just keep myself in the habit of making the part my displayed part before creating any attributes. Well that turned out to be a book didn't it?...lol. Let me know if you have any more questions.
Take care...
Thanks again!
t.
t.
Take care...
Thanks!
t.
Take care...
