Pump Casing Overpressure Allowance?
Are there any design codes or regulations that allow the maximum pump casing pressure to be within 110% of the casing design pressure? ASME Code Section VIII addresses 10% overpressure allowance for a pressure vessel, but it is only applicable to a vessel with a overpressure protection device like a relief valve. I am not sure if it is allowed (by codes or regulations) not to do anything to a pump case as long as the maximum case pressure is within 110% of the design pressure.
Thanks in advance for your advice.
RE: Pump Casing Overpressure Allowance?
