admissable percentage of voids in a die cast part
what is the admissable percentage of voids admissable in zinc die-cast part?
Does the size of the part count?
thanks in advance
chaiduc@fortlock.com
thanks in advance
RE: admissable percentage of voids in a die cast part
Having said that, the approach to defining acceptable flaws can be done by 1) determining the level of stress within the part, 2) using fracture toughness or J-integrals to define the material's strength and 3) creating a "map" of the part that defines critical flaw size for various locations. Once this is known, a suitable inspeciton method (ultrasonic, eddy current, die penetrant, magnetic particle, radiographic, n-radiographic, etc.) can be used. Each has its own positive and negative aspects and an optimal inspeciton plan (one that finds critical flaws within reasonable cost constraints) can be established.
Voids typically cause problems because less material exists for strength in areas where strength is needed. They can be mitigated by using larger part section areas. Voids indicate potential problems with part fabrication processes and, although acceptable from a strength point of view, may be symptoms of other problems. They can also contain foreign material which can have other affects on a part (corrosion resistance, etc).
The admissable percentage can be established by down-rating the load bearing area of the part by the percentage of void content. This is simple and often effective. Voids are stress-risers. They have small radii that serve as sites for high stress. Materials that are "brittle" can be much weaker than indicated by the void percentage content because these peak stresses are not mitigated by local deformation at the void edges - instead of redistributing stress, cracks form and failure occurs. Ductile materials are often much more tolerant of voids than high-strength materials.
Also, voids may be acceptable from a static loading perspective but will fail prematurely if exposted to cyclic loads - the endurance capability of a part is reduced significantly.
