SW06 BOM's hosed
SW06 BOM's hosed
I was wondering if others here are having problems with their BOM's in SW06 SP1.0. I am using the default BOM (bom-standard) with "Top level only" checked for the BOM Type. The balloons are picking the individual parts of each assembly instead of the top-level assembly the balloon is attached to. I am having to overide the balloon numbers to match the BOM for now, but I would rather not have to do this.
By the way, if the columns in the BOM are left-justified, the text is butted-up against the BOM vertical lines. I know how to increase the cell padding, but has anyone found a way to save the modifed BOM as a template and have it keep the cell padding modification?
Flores
SW06 SP1.0
Flores
SW06 SP1.0
RE: SW06 BOM's hosed
As for your other issue... Open your assemblies that you want to show up as onr item in your bill. Go to the Configuration Manager, right-click the default config & select PROPERTIES. There you should find a box to check that will force this assembly to not show child components...
See if this fixes you good.
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP01.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
Flores
SW06 SP1.0
