nested repeat regions in pro/e 2001
I have created a nested repeat regions in 3 levels.
In the first column, I want to filter out the items that we can find in the second or third column.
The attributes in the outer repeat region are set to 'no duplicates recursive'.
In the middle repeat region to 'no duplicates flat'.
In the inner repeat region to 'no duplicates recursive'.
The problem is that the assembly haves subassemblies in different levels
