Inventor Studio Problem
Does anyone know if there is any simple way to create an avi recording from an animation created in Inventor Studio. The Render starts a recording that takes hours to create and results in a massive file size. The old recording method in Drive Constraints in the model gives you what you see on the screen which is what I need to do but in Inventor Studio. Any help greatly appreciated. Thanks
Dominic
RE: Inventor Studio Problem
Note the resolution of the animation, and the compression rate. This is most likely the cause of the huge files etc.
I BELIEVE that you can still use the old fashion route of record during constraint driving?
