Need help creating Delta Angle Symbol in dimension text
I need help creating Delta Angle Symbol in dimension text. You know that little triangle symbol. Is there a key command to make it like the degree symbol (Alt+248)?
thanks
thanks
RE: Need help creating Delta Angle Symbol in dimension text
If you have autocad 2006 it is built into the multiline text editor.
the command is \U+0394
thanks though
