Reverting to SP1.0
Reverting to SP1.0
Is it possible to un-install SP2.0EV and go back to SP1.0 without reinstalling SW?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Reverting to SP1.0
Wes C.
In this house, we OBEY the laws of thermodynamics! - Homer Simpson
Rob Rodriguez CSWP
www.robrodriguez.com
SW 2006 SP 1.0EV
I don't suggest doing this. I have seen more problems doing a rollback then if you just uninstall and reinstall.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I created a drawing of an assembly made out of subassemblies and parts. I created the BOM. Opened each component and updated the custom properties. Going back to the drawing the changes reflected in the BOM. Saved the drawing then printed. Closed the drawing, saved averything and closed SolidWorks. I opened SolidWorks again, opened the drawing. All my changes that I have made,seen in the BOM and printed are gone. This happened only for subassemblies, not for parts.
I rolled back to SP1.0.
Opened the drawing. Opened one subassembly, changed the description, saved it, closed it. The new description showed in the BOM. Closed the drawing. Opened the drawing. The BOM shows the old description and the subassembly, indeed has the old description. Very strange behaviour!!!
Tomorrow I'll have to clean my computer and reinstall SW.
Report your issue directly to SW and see what they have to say about it.
I don't install it until it full production release and it's been a couple of days since it was released.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
If you go to the CP of the parts do you still see the changes there?
This may sound stupid, but did you save each part after you made the changes or did you just close it all without saving?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
It happened every time with this assembly drawing. And only with properties of subassemblies. Parts component properties were stable.
Since then I deleted the drawing and redone it. Using the same steps. Now it is OK. The difference between this one and the previous one was the SP, this new one in SP1.0, the one with problems in SP2.0EV.
Scott, this is do strange that if someone would have told me this story I wouldn't believe it. I would suppose he did something wrong.
