Reattach Center marks???
Hi, I have a part that have a lot of holes in it. For design questions, I have to add an extrude feature in this face, so my sketch include the holes as well as the form of the extrude (Yes, I know there are better ways to do this, but this was the best way in this case). I made my drawing and add center marks in the holes. Now, I'm reusing the part but I have to suppres the extrude, and the centermarks now appears in yellow. I think this is because they lost their attachmnet with the hole, and I was wonder is there a way to reattach this marks with the holes, Because If I erase it, all my dimensions gets lost too, and there is a lot of redimension if I do this.
Thanks for your help!!
Adi Corrales Magallanes
Centro de Ingenieria y Desarrollo Industrial
Queretaro, Mexico
RE: Reattach Center marks???
This has been a long standing issue, but an understandable one. One thing I always always do is dimension to the hole, not the center mark. This may not always look pretty, but you can adjust the witness line if you need to. By dimensioning to the hole, the dimension will be much less likely to have problems.
John
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Queretaro, Mexico
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
