Scaling Assemblies for Rapid Protyping
      Running SW'05 SP4.  I have an assembly of about two dozen parts and I'm trying to scale the whole thing 1/10X at once to be saved as an SLT for the rapid prototyping machine rather than scaling each part individually.  Anyone know of a "Scale Assembly," function?
Dale
RE: Scaling Assemblies for Rapid Protyping
Dale,
I just tried this but you could save the assembly as a part then bring the part into session then apply a scale.  The only problem is the solid bodies need to be repositioned.  If you are doing a SLA model the manufacture will want individual parts not an assembly.  I just got an enclosure done in SLA and I did all the parts individually.  maybe I'm missing something here
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Well, if your "assembly" has multiple bodies after saving as a part--and if those bodies are truly separate entities, you can go to Feature > Save Bodies to save each body (after scaling) as separate parts.  (But then you'll need to open each part and export to STL or whatever you need as a file format.)  This solution will still require some messing-around time for all the scaling and exporting.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Please feel free to contact us at Paramount Industries for more techinical expertise in this area.
Thanks!
Paramount Industries http://www.paramountind.com
Doesn't the rapid protype machine have the scaling built into it?
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
