IMPORT PDF TO AUTOCAD
Somebody know if is possible import a PDF file to Autocad?????I appreciate you help thanks so much......
RE: IMPORT PDF TO AUTOCAD
http://www.eng-tips.com/viewthread.cfm?qid=32798
http://www.eng-tips.com/viewthread.cfm?qid=22994
http://www.eng-tips.com/viewthread.cfm?qid=58836
Lothar
ADT 2004
ACAD 2002
ADT 2004
ACAD 2002
It sucks if you need to modify the detail though. Then you have to pretty much draft it all out unless you know someone who already has it and would be kind enough to give you a copy.
A lot of items will some in as splines, but I haven't yet found a way around that.
