Relief valve opening
A high pressure air(1800 psi) valve (2") supplying air to a test fixture closes rapidly. Up stream a controller senses the pressure spike and is supposed to secure the air source by closing another valve. However, it can't react fast enough and the pressure spike lifts a relief valve (2000 psi) in between. Any ideas on how to stop this?
RE: Relief valve opening
If it is a case where the normal operation is lifting the safety valve then the upstream conditions should be changed to prevent the overpressuring of the downstream system.
That way it seams that you could get rid of this on-off valve and install regulating relief valve instead (it is similar to safety vlave, but designed in a manner that can survive lot of openings during operating life while maintaining precise pressure - you can find it in many catalogues).
Your safety valve should have higher setting than this regulating valve and should serve to protect against apparent malfunction - not to open all the time.
If so is the downstream valve a pneumatic actuated valve (with e.g. spring to close)
if yes: Why not put the two valves on the same solenoid valve so that when one valve close the other will close too?
Best regards
Morten
Slow down the valve that isolates the test ridge so the controller and air isolation valve can catch up.
Install a pilot operated relief valve and dampen the supply line to the pilot.
