Staking Teflon Wire
Staking Teflon Wire
I am looking for a material that would stake teflon coated wire to steel. I am hoping for some of the following characteristics:
1. relatively thick, quick cure
2. chemical resistant to degreasing solutions commonly used to remove flux when soldering
3. non-conductive, good insulation properties ** important**
Thank you for your time and suggestions
qu1nn
qu1nn
Qu1nn
RE: Staking Teflon Wire
Something like that would work in your application, except of course that nothing really sticks to Teflon. I.e., you can't bond to the insulation, you have to trap it in place.
If you built up the CA to form a bridge over the wire, that would be better, but it wouldn't be a very durable setup. It would hold the wire in place long enough for a big ol' blob of RTV silicone to set up.
Mike Halloran
Pembroke Pines, FL, USA
