Deflection Criteria for Slate Tile Wall
I am working on a building with a slate tile facade.  Does anyone know the appropriate deflection criteria to use for the design of curtainwalls and spandrel beams?  Any help would be much appreciated.
-Zach Lindauer
RE: Deflection Criteria for Slate Tile Wall
For brittle materials, I have seen deflection limits ranging from L/480 to L/640.
Thank you for your reply SperlingPE.
Perhaps some additional information would be useful. Slate tiles are proposed to be attached to 3/4" plywood with hooks. No grout will be used in this application. This will allow the tiles to slip in relation to one another without causing stresses within the tiles.
I believe this is very similar to a slate shingle roof, which would be designed for L/360 total load deflection. Does this seem reasonable?
ZFL, that is an interesting application that I've not encountered before.  slate isn't used much around here.  just curious:  are the tiles lapped similar to a roof?  What is the plywood attached to:  metal or wood studs; CMU?  unless there is industry data to the contrary and no concern about too much deflection causing leaking problems between the tiles, L/360 would be reasonable in my opinion.
The tiles are arranged in a half-lap pattern.  The plywood is attached to metal studs.  I have not been able to find any industry data regarding this condition.  All opinions on this are very much appreciated.
-ZFL
I've looked for info on the 'net, also.  nothing so far for slate used for siding.
