functions in msc.adams
I am having some probles creating functions in aview how can i best create the yaw and lateral acceleration functions, thankyou
RE: functions in msc.adams
lateral acceleration is the y component of the acceleration of that marker.
You have two alternatives. Right click on the CG marker of the body, and choose measure, and select the appropriate measures.
Or, if you want to generate a request, use build->measure->request-> new
Its hould be pretty obvious from there.
Cheers
Greg Locock
With View I recommend you do the latch example, right through to the bitter end. It's a bit tricky, but it does show you a lot of useful stuff.
You can also try the on-line forums at www.adams.com, where they have a useful database of questions and some more tutorials.
Cheers
Greg Locock
