fluoro silicon elastomer
Hi everybody, I have to glue a fluoro silicon sheet on a painted aluminium support. Do someone know which kind of product will permit it? or which manufacturer can satisfy me in such application?
The elastomer is an aeronautical reference 61D8.
RE: fluoro silicon elastomer
You may want to post this on a material forum as well.
I've got in touch with Eleco Produits (adhesive manufacturer) who have recommended me also a silicon adhesive. I will mention to not paint the glued areas.
I got back to the office and looked up the adhesive I've used in the past. It's dow corning 3145, another part number for this is M46146-31XGN. This will bond silicone to metal. Ensure your aluminum is not painted but does have a conversion coating (alodine or anodize).
Good Luck
which brand is it M46146-31XGN and 3145? I have already chosen the glue (RTV 157 from Eleco Produits)
The aluminium will have an alodine. There will be paint resists where the elastomer should be bonded.
Thank you
For more info see AC 45-206 part1 - pages 15,85 and table 5-2
www.airwe
