friction losses in smooth walled pipes
Osborne Reynolds conducted experiments in Manchester in the early 1880's to determine the nature of flow in pipes (laminar to turbulent)and demonstrated the onset of transition at reynolds number above 2100.
Why did resent experiments in Manchester(using his original equipment)discover the onset of of transition to turbulence at significantly lower Reynolds number?
RE: friction losses in smooth walled pipes
Also, modern instrumentation is very likely to be orders of magnitude more sensitive than anything dreamed of in the 19th century.
Another possible reason for the difference observed may have to due with deterioration of the original equipment. Is it possible that the equipment may have corroded (increasing its relative roughness) over a span of 120 years? I think so.
