High temperature light fixture florescent lamps
We have light fixture 2X 36 watt, 240 Volt florescent lamps with ballast, and we found MCB always tripped due to damage of the ballast and wiring inside light fixture, then we measured the temperature at light fixture during normal operation we found it reached to 100 C because it is between two furnaces and its required lighting at this area.
Please can you give me name of manufacturer have light fixture with high temperature around 90 C or 100 C with ballast explosion proof Type: Ex s e q d II C T4
RE: High temperature light fixture florescent lamps
http://www.pfp-elec.co.uk/
One day my ship will come in.
But with my luck, I'll be at the airport!
