NDT & Mechanical Properties
Is there a NDT instrument that can measure mechanical properties? Such as ultrasonic, eddy current NDT? I realize known standards would probably be needed to calibrate such a device/method. What I have is a wrought aluminum stucture that I would like to measure its yield or tensile strength non-destructively. Hardness testing is not acceptable.
RE: NDT & Mechanical Properties
See
http:
http://www.buzzmac.com/bsuses.html
X-Ray diffraction can measure local superficial state of stress
See
http://
It is unfortunate that hardness testing is not acceptable.
May be microhardness?
http://www.welding-advisers.com/
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Sorry but I dont know how to put a hyperlink, so please cut and paste to your browser.
www.ndt.net/index.html
Search on "materials characterisation" or search the WCNDT papers over the last few years. Much research information on there about the subject.
