Silica:colloidal or reactive?
Usually, when people report silica content of their waters, they do not say if it is "Total silica", "Reactive silica", or "Colloidal silica".
How do you interpret such numbers?
RE: Silica:colloidal or reactive?
Colloidal silica is typically found in surface waters and has created problems for water treatment because of its stability as an un-ionized compound, making it difficult to remove using ion exchange processes.
Silica is at the lower end of selectivity for anion resins, creating a scenario where silica breakthrough is one of the first to occur. As a result, silica can be effectively removed only if the ion exchange resins are completely and properly regenerated.
With the introduction of RO as a pretreatment process, the colloidal silica can be removed very effectively simply by virtue of the filtration capabilities of a typical RO membrane. In fact, if one uses a conventional definition of colloidal silica as that which measures greater than 50 angstroms, even ultrafiltration with a molecular-weight cutoff (MWCO) of 100,000 daltons is effective at removing colloidal silica. The RO also helps the ion-exchange process by alleviating the overall silica loading on the resin.
Pretreatment is prudent on a demineralizer makeup water supply. You are trying to make ultrapure water and there is typically a lot of crap in the normal municipal water supply.
we do not have access to the lab which provided the analysis,always. I read bunch of articles in Chemical engineering magazine, CEP, and so on and I have seen some papers in recent "international water conference", But none of them addressed differentitation between TSiO2 and RSiO2.
and my question still is: What do those numbers mean?
Total silica should be the sum of the reactive silica and colloidal silica. But total silica may not be expressed that way and colloidal silica may not show up on such tests.
Colloidal silica is insoluble and is something that can be filtered out with a whatman filter. Reactive silica is dissolved
Colloidal silica is difficult to detect in low (ppb) concentrations, and not many labs are capable of providing analyses.
With the AA/ICP method, a portion of the sample is injected into the machine and the silica content is measured. This is the total silica (both reactive and colloidal). Another portion of the sample is filtered through a 0.45 um filter (colloidal silica is retained on the filter). The filtered sample is injected into the machine and the silica content measured. This result is the reactive silica. The difference between the two silica readings is colloidal silica.
A similar proceedure for the molybdate blue method is followed. A portion of the sample is analyzed according to the ASTM method, resulting in the reactive silica content. To convert the collodial silica to reactive form requires a hot, sulfuric acid digestion first. Then the molybdate blue proceedure is run. This results in a total silica reading. The difference between the two is colloidal silica.
The AA/ICP method is more accurate and faster but requires much more in analytical equipment investment and a much higher level of training for the personnel operating the AA/ICP.
So, appearently, there is no way to understand or even guess if a "silica" concentration is total or reactive or colloidal, if originator of article did not say anything.
Thanks again
The colloidal silica is the most troubling, especially if the treating water for steam generator makeup since the temperature and pressure in unit will convert the colloidal form to the reactive form.
